What I'm actually trying to accomplish is getting cyanogen back on here
Do you still have the Cyanogen .zip file? If not, click under this post to my signature to find some ROMs for the phone from XDA. Once you've clicked the link in my signature, you will be taken to an XDA page that looks like a Wikipedia page. Cycle towards the middle of the page to find where the CM7 ROM is and begin your download.
Once you have downloaded the .zip to your computer, you will now need to move it to your phone's SD card. You can also download the .zip file directly to your phone and it will be put on the SD card.
Make absolute sure to put this .zip file onto the ROOT of your SD card. By "root" I mean the first place you will start when you open your SD card on your computer. Do not unzip this file either. Just put the .zip file on your SD card as it was when you downloaded it.
Once the .zip file is on your SD card, turn off your phone. Now, turn on the phone by using the "down volume switch" on the right side of the Evo and at the same time, hold down the power button. Once this is done, you will be at your HBOOT screen. At the very top of the screen, it should say "S-OFF" meaning that you can flash a ROM like Cyanogen to your phone. If it says "S-ON", you will NOT be able to flash this ROM.
If it says "S-OFF", use your volume button to scroll down to "Recovery". Your phone will reboot and after about 30 seconds you will be at your Recovery screen. Scroll to "Wipe" and wipe everything from your phone but do
NOT wipe
anything from the SD card. Scroll around through this menu to find where to "Install .zip from SD card". Depending on which Recovery you have (either Amon-Ra or ClockWorkMod), the menus will be a bit different. Once you have done this, search your SD card for the .zip file for Cyanogen ROM. Let it install and once it is done, reboot your phone.
It will take a few minutes so give it about 15-30 minutes to fully install. Once it is installed and it comes to the home screen where you can unlock the phone, let it sit for about 10 minutes extra just to let it adjust and it should work much better.
Now you should have Cyanogen ROM back on your phone!
If you need any more help, feel free to ask here or back on the forums or check in the "Rooting for Dummies" section of the Evo forum and read up on how to flash ROMs and do all sorts of other fun stuff.
I hope that I have been a help. Feel free to inbox me if you need further help or to ask here and welcome to our forums! I hope you enjoy your stay and feel as welcome as I did when I first came here
