EVO as second monitor???
danj1111
any software to make my evo work as a second/third monitor?
to clarify, I'd like to be able to connect my evo to the computer using the
usb cable and have it show my computer's desktop as a second or third monitor. (I already have 2, but would like a 3rd for playing movies or something)
just a thought. Thanks!
I am also looking for this I have a laptop with a broken screen that I want to take to work so I am not takin my nice one everyday. The other one was nice till my son decided he wanted to step on it and yep no more screen... LOL he is 2 and was an accident but would be nice for it not to go to waste.
Thanks
Dj
That would be awesome, but i dont see it happening any time soon.
I can see a lot of uses for it: keep media player playlist open on the phone, photoshop pallete's, bookmarks while in a browser.
Thanks
Dj
this wouldnt really help you as it would require configuration and setup on the laptop also. but you could always get a used cheap LCD off of craigslist or u can get a new 19" monitor for under $100 bucks anywhere.
I would also like to know if hdmi in is a possibility. I work for a cable company. Sometimes I install at homes with no tv. Instead of rescheduling I could use my phone to show there set top box works....
I'd like to see my EVO levitate. Any software for that?
You'd like to see your EVO levitate what? If you just want it to levitate a feather, yes, there's an app for that, but with the battery life as it is, I don't think it can levitate a car for very long...but think of how nice that would be in a traffic jam!
The basic question is whether the HDMI jack on the Evo is only an output, or is it capable of input also?
I would think that it is only for output and thus you can't use it for receiving signals.
well it works over wifi for the ipad, and shows up as a secondary monitor, basically would be like VNCing to a second screen.
I have not seen anything to support input over hdmi
It should be pretty simple in fact:
1. Create a virtual second monitor on your system. Pretty simple in windows: ZoneOS ZoneScreen
2. start a vnc-server on that virtual monitor
3. use a vnc-client for android to connect to that second screen
So in the end you'll have a virtual second screen that is visible in you android device...
You can try this App. It may not let you use your PC as a second monitor but you can fully use your Mobile Device to minipulate your PC over an Internet connection to your PC and a WIFI/3G+ on your Device. I use it quite frequentely.
You may even be able to use it as a second monitor.
Try setting it up and see if you can grab it with your phone. If not, email the developer, I am sure they can get something going.
PhoneMyPC
by SoftwareForMe Inc.
10,000 downloads, 2795 ratings (4.4 avg)
$9.99
