I'm pretty sure that it never used to have this problem, but don't recall when it changed. I was never too too much into using the camera since I have a Nikon D300, but there are definitely times I do want to use it. Sometimes the focus will be almost there, but you can tell it's still well off because the area in back of where I want it focused on is mega sharp. It doesn't matter if I use the finger tap to the screen and hold method or if I just use the shutter button method. But when I DO use the finger tap and hold method, it back focuses a LOT more.
After doing some tests just now, it seems that it's an issue with depth. I can get a really sharp image of anything on a flat plane, but if there's any depth, it will focus towards the furthest most back part of that object. But then again, it also depends on the object as well. Look through this gallery and this becomes evident. The first photo has the object I focused on captured in really good detail and shows good DOF with the background.
But in all of the flower shots, I'm putting the focus on the stamen in the foreground, and it back focuses all the time. In fact, it just seems to not want to focus on any of the foreground of the lily's, only the back. I wasn't moving, and I wasn't too close. Those shots of the swiffer mop are pretty darned close though (5 inches away?) and had no problems getting a sharp image of it. Same goes for the vinegar bottle n' such.
What's up with that?
Here's the link.
Look here
I wonder if this is something fixable and how much it would cost. Because the camera performs quite well, aside from this really poor focusing issue. It's a good thing to have in a pinch if it works right.
Doug
Edit: Not sure what happened during upload but now all the photos have been mangled a bit at their bottoms. Meh@Google and uploading from Android.
Here's the link.
Look here
Doug
