Replaced this EVO with a brand new motherboard, and also got a brand new battery. This wasn't happening on stock though. Got it only last week.
on stock what? ROM or Motherboard?
Who replaced the motherboard?
new battery doesn't necessarily mean its a "Good" battery it still could be bad. Could try another battery.
I personally replaced it, everything was working fine. Tried other batteries, none worked.
I was on the latest stock 4.54.61.1 (I think those are the numbers...), and the motherboard is HW 0004
If you need my history of event's I'll tell you what I've done.
1. S-OFF and rooted with Revolutionary.
2. Revolutionary wasn't flashing recovery properly, so I had to manually flash CWMR with Fastboot in ADB.
3. Got in CWMR, and flashed gingerbread-evo-deck 1.3, flashed Google Apps. Rebooted, issue began happening.
4. Went into HBOOT, and tried to change recovery to Amon RA, see if it'd do anything, nope.
5. Went into recovery, and tried to flash SavagedZen, nope.
I tried the complete wipe. It didn't work.
I also just tried to RUU back to stock, and my device is rebooting on its own now.
The complete wipe option usually only does data and cache you need to wipe everything except sdcard
Actually. I fixed it. It turns out my USB was "bricked". I followed this guide: [ How-To ] Fix SD card not being detected & USB port not working - xda-developers and that fixed the issue.
