Root Evo freezes when overclocking
cremona
I have tried a few kernels, baked snacks #3 i think and kings...everytime i try to overclock past 113600 it freezes....any reason why?
ive used different roms like cm6, myn2, and baked snacks 1.7
Im only able to overclock to 1.152 anything past that freezes for me as well. Im using KingsxKernal. I could use some advice here as well.
If it freezes then your phone does not like that value,set ur speed to a lower value or try a different kernel.Most likely this will be a phone issue not Kernel IMO,so regardless of what Kernel you use your phone will most likely do the same if try to go any higher.
Yup 1152 seems to be the sweet spot for most. Amy more and phone will freeze or boot loop
I can go 1.267 using Baked Snack without a problem, but I, too, have locked up going past 1.1x on others.
