1) More then 30fps without having to hack
2) longer battery life
3) better recption
4) More stock version of android
5) better camera
6) faster proccessor
7) wayyyy faster gpu
8) better constuction, not as much plastic.
9) hard buttons
I'd switch but the X doesn't have a kickstand and I use mine every day for 8 hours at work.![]()
Have you seen the accessories for the Droid X? There is a case with a kickstand, check it out:
http://www.androidcentral.com/sites...-x-accessories/DROID X _Accessories FINAL.pdf
Problem solved.
since I'm a vegan I have to keep looking for a plastic version...better camera? how can you tell without seeing it for yourself.
faster processor? GPU is better which makes it perform faster. CPU isnt the issue.
better reception? they're on different carriers. how could you compare?
Too bad its leathersince I'm a vegan I have to keep looking for a plastic version...
You're assuming it's real leather.
I had an Evo and I am coming to Verizon for the x
Thank god for Sprint's 30 day no cost return policy am I right?![]()
