I need to try a new radio to get better reception in Raleigh, NC. Thinking about Evo radio 2.15.00.08.08 found in this XDA thread. Is this safe or do I risk bricking the phone?
I'm running CM6.2.
I'm running CM6.2.
I'm running CM6.2.
That's the radio I'm using. Getting terrible signal in North Carolina with that.If I were you, I would flash the latest radio which I believe is this: [Radio][28th November 2010] 2.42.02.10.29 Sprint CDMA Hero - xda-developers .
Yeah, I updated PRL to 60681, didn't help signal.Have you tried restoring your Nandroid back to stock and getting the latest PRL? That might help a little, but it is probably a long shot.
I'm in Raleigh, and getting poor signal everywhere here. My home was the worst, but got Sprint to send me an Airave, so home signal is strong now. Outside the Airave's range, it goes back to being lousy.Are you getting lousy signal everywhere in North Carolina or just where you live or work? If it is where you live maybe you can get Sprint to give you a signal booster for your house. It is called an Airave. It might be worth the shot.
Appreciate the suggestions.Alright. Well I am plum out of ideas then, man. It looks like you have already tried everything that I suggested. Unfortunately, you are not the first person that I have seen have issues with signal strength in North Carolina.
It's a lot simpler than that. You don't change the radio, just the PRL, so the phone looks for Verizon towers, which as we all know, are practically everywhere in comparison to Sprint towers. If you're on an unlimited data plan, you don't get charged for data roaming, though people who abuse this sometimes get letters from Sprint asking them to leave, but that seems to be for really egregious use, like several GB/mo roaming.I never really messed with Verizon radio basebands on Sprint handsets. I did not want to take the chance of bricking my handset.
Switching back to Sprint towers is as simple as updating the PRL the way you normally do.
where are you in raleigh that you get bad signal? I get 3-4 bars pretty much everywhere around rdu.
Also, I HIGHLY recommend you dont use a verizon prl too long. 100% roaming is a fast way to get a letter from sprint telling your service has been discontinued
