I recently installed rooted and flashed my Evo V 4G.
Everything seemed to be working well and I managed to flash the ODEX ROM mentioned in the guide, making a recovery and everything. After I did that, I attempted to flash the CM10.1 Android 4.2.2 ROM for Sprint Evo 3D (to my understanding this should work with the Virgin Mobile version as well?). After flashing, the CyanogenMod logo popped up and a screen stating that it was initialing and updating all the apps came up. Once that finished, however, the phone began to constantly reboot itself without me ever actually getting to use the ROM itself. It simply displays the HTC logo for a bit and then the CyanogenMod logo before rebooting again.
Since I still have access to TWRP (removing the battery, then pushing down the volume button plus the power button), I attempted to load the backup that I had saved prior. However, after a long time (1066 seconds), it loaded only to suffer the same rebooting fate (although it no longer says Cyanogen Mod since the backup was saved with the ODEX ROM). Is there any way I can simply access my phone normally again (I don't care if I have to return it to stock conditions in order to do so). Thanks.
Maybe the ROM is bad?
