So with S-Off, the fix everything "fixes", and a custom ROM this phone is 100% solid then? I'm very familiar with rooting and such so I don't imagine i'll have much trouble modding this phone. From a quick glance at the All Things Root section Mobster Rom looks promising. Unless someone can recommend a better ROM? And thank you for all the replies. I'm officially sold on this phone and will be joining this community soon.
Side note: Still looking for advice on an aftermarket battery
EDIT: Ordered from Radioshack ($229 + S&H). Will have phone by the end of the week. Thanks for all the feedback!
It's a VERY solid phone once you do that.
It's what you would expect from a nice, high end phone.
I hate the idea that you have to root, rom and flash to make it work right, I bitch about the Triumph for that very thing. However there is a big difference, not only do we expect a fix from HTC any time (because it IS a software issue), the fixes
we have are not workarounds, they are proper fixes.
As for solid roms... Mobster, Midnight, and Harmonia seem to be the big three. I would try all three and see what you like.
One great thing about this phone is accessories, and the fact that they are CHEAP.
Batteries:
Personally, I love Anker. Get a 10-20% without a thicker phone for under $20. This gives you a little extra juice for daily use and a spare battery for when you need it. They also sell higher capacity ones, but Seido may be a better option as they make docks that are compatible with their extended battery and case if you want one. OEM docks cannot handle cases or extended batteries, Seido stuff can. Personally, I only run a cheap screen protector (Ebay generics).
One other thing I recommend, get a dock (I have the OEM), just drop it in, and it charges. No fiddling with cords (who needs a Powermat?) and it gives you a nice bedside alarm clock. This is the second phone I have had with a dock and I will probably never own another phone without one, I ordered this dock almost as soon as I got the phone because they are just so convenient. I even went so far as to buy my mom a dock for her One V for the same reasons. You can get them for about $10 on Ebay, you won't regret it.
There is also car docks, I haven't tried other quality ones like Seido, but
the OEM is VERY nice and I would guess the others are too. The generics stink as always. OEM's can be had for about $12 and come with a nice quality car charging kit. Another thing you will want.
