log3an
Hi all, hope someone has an answer, to that person I'll owe a thousand bucks, if you can read this=D To everyone else, don't do what I did, whatever it was.
I have a Sprint Evo 4G stuck on stock; the Hboot is damaged, the recovery.img might be screwed and the PC isn't detecting any USB connected Evos. I just need to Permanent Root or reflash.
This Is What's Wrong: (Note: I've tried most noob-capable attempts and am aware of the necessary settings/steps)
1. PC doesn't detect USB connected/debug enabled Evo
2. USB selection on Evo seems broken. Only the 'Debug Enabled' notification alerts of activity
3. All update.zips fail Signature Verification in Recovery
4. Hboot 'SD Whatever' it said doesn't say it anymore when HBbootloads and scans the SD card
5. Hboot USB does nothing when the Evo and PC are connected.
What Works:
1.This fast ass processor, hells yeah! I'm on a Huawei Ascend that I first Cm6 flashed. When Cm7 was released, 6 was barbaric. I completely see now how crappy that stupid little turd was altogether. To anyone else trying to turn a tinker toy into a tool, GET a tool to turn into whatever and you'll be 947k times happier.
Assumed/Possible Solution Routes: (Over-my-head ideas to fix this, are any possible?)
1. Fix Signature Verification(s) for Recovery update.zips
- About this, I got error 'E: Error in cache/recovery/command' in Recovery, so with Root Explorer I made recovery and command folders with their respective permissions and now get 'Error in CACHE: recovery/command (Bad file number). Was my guess at all close to fixing that?
2. Somehow reflash Hboot with S-ON in Recovery
3. Android executed 1-click/auto/apk permanent Rooter
4. S-OFF during z4Root's temporary Root
5. Manual missing/broken system file replacement in Root Explorer
6. Terminal Emulator - USB Debug or .img flash?
Thanks again for the help, Boo, I look forward to reading it. Lol, I'm joking, you're not my f$*$%in boo
What Works:
