I am expecting more than 5 days of battery life using the stock battery.
Right now I'm at 79% and it's been 40 hours since unplugged.
This is what I configured:
Rooted
Installed ROM superevo
Installed Kernel 7.6 BFS SnapTurbo enabled
Installed setcpu with profile of screen off set to 245mhz, while keeping regular usage at 1ghz
Turned off back ground data
Turned off 3g
My minimal usage so far contained:
1 missed phone call
2 short phone calls (total probably less than 5 minutes)
3 text messages
2 sessions of manually turning 3g on and autosyncing my work calendar
2 sessions of short usage of navigating around the phone (calendar, settings, etc.)
10-20 times of pressing power switch to check clock
I will update again when my battery finally dies after minimal use, and also grab a shootme screenshot.
Good battery life can be attained!!!
Update:
I wrote up a post-review on my blog:
http://edsandroid.blogspot.com/2010/10/7-days-battery-potential.html
Rooted
Turned off 3g
1 missed phone call
3 text messages
Update:
