ccsoccer03
I am aware that there are ext 2, 3 and even 4. My question is... Are all compatible with the apps2sd equally and backwards compatible? I reformated my partition from ext2 to 3 then to 4. I haven't seen anywhere that talked specifically if a particular apps2sd program required a certain type ext partition. Thank you for your time!
