No this phone only supports up to 32GB card.
What makes you think this phone only supports 32gig cards? Just because the package says that? I've seen multiple phones claim that and still work with larger cards.
Well go and test it out and come back with screenshots. Don't be a pompous ass about it.
Has anyone tried a 64GB SD Card yet?
The Awe uses the same battery as the sequent, so I'd start there. I've got a pair of 2280mAh batteries I got for $25ish on ebay.
Do you have any additional information on these batteries? I cant seem to find any over 1800mAh...
I picked up a Sandisk 64GB chip to use with my Awe but it didn't see the card. I reformatted it to Fat32 and it still didn't see the card, though I checked it out and both my Monster M7 tablet and my old Motorola Triumph recognize it. So I put it in the Triumph, which I'm now using as an mp3 player.
I also partitioned it into two 32GB drives and the Awe didn't see it.
So I bought a 32GB chip and it runs fine in the Awe.
Give rbheromax's kernel a try with the 64 GB card
I too have a 16gb, but I believe the largest the phone will accept is 32gb. This is a hardware limitation if I understand correctlyGive this a try with the latest awestruck beta kernel. Make sure you format the card as exfat on your computer first. My largest card is 16gb so I can't test.
