Accessories Extended Battery -- 30 hours in, 55% life remaining!
Ecks
Just thought I'd give some encouragement to those who are on the fence about the verizon extended battery. After a day of pretty good use (lots of texts, lots of market browsing, several gmail emails replied to, 2+ hours of games played (solitaire, tower defense, puzzle games, etc) I am sitting today at being unplugged for about 30 hours (give or take 15-30 min) and my battery widget is reporting 55% left. A substantial increase over the stock battery, which I couldn't get more than maybe 8-10 hours of use before my phone would die.
I'm hoping to make it to the 60 hour mark before having to recharge. Just very relieved -- I travel often and didn't want the burden of day-time charging while I'm away.
Also, I'd like to say that letting your phone charge fully while turned on, then unplug it, turn off the phone, and charge it another 30-60 minutes, it will add much more life to the battery. Just a note for anyone who's going to be away from a charger for an extended period of time. Also, I did let the extended battery fully discharge after the first full charge.
* No task killer
* Using Launcher Pro
* Wifi only on when I'm at home
* 1 minute screen timeout
Any pics? I'm curious what the extended battery back cover looks like and how much different the thickness is from stock. thanks
Considering the 2150 is 65% more mah, I must assume then that the OP got about 10.5 hours with the stock battery and still had 55% life remaining. Which suggests the OP does not use the device much.
Just some brief browsing through the day, a few calls and a few games & music got me to almost 10 hours with stock, but only 10% juice left.
Still, in order to get the relative performance the OP describes, the extended battery would need to be about 3600mah? At least in that range.
Everything is relative.
I have the stock battery, 40 hours unplugged, 60% remaining. It means very little. Use only your 'awake' time listed under battery details.
