What extended battery is better the qcell 3850 vs 3900 mahNEW AceSoft High Capacity 3900mAh Extended Life Battery Back HARD Cover Door for LG Connect 4G MS840 MS 840 MetroPCS Cell Phone Accessory USA:Amazon:Cell Phones & Accessories
I've also heard that the qcell 3850 was actually 2800 mah. What does the 3900 measure in mah
the temp censor for your qcell works eh? my phone can get pretty hot at times and it never registers over 89F even when it feels like its about 100F.I've got the QCell 3850; and I can attest that this is probably true because it doesn't really hold up any better than my 2600 that I had in before it. The phone idle time is a lot better though, and the temp sensor in it actually works (first battery I've owned that did.)
On the 2600 idle I'd go from 100 to 35% in the four to six hours I sleep; whereas on the qcell I go from 100 to about 90 to 80% in that time, so it's got something in it keeping idle (screen off) times at a very minimal draw....which is great since I'm not using it, but in use I'd say it's no better. Could just be that it draws harder; not really sure.
65% loss of battery juice while sleeping? that is terrible. have you measured the true mah for your qcell battery or the 2600mah?
you said you got 4 hours from your 4G video streaming tests correct?sorry guys my 3850 is around 3900 absolutely great battery really feels like way more than double. i think its a batch thing
so you're getting a measurement of 1000 more mah than i am but around the same pperformance as my battery?actually i got around 4.5 hours of streaming video but there was probably 15 to 30 minutes between replay because the video was only a bit over 2 hours and i wasnt paying attention the first time it played
I'm thinKing about getting a 1900mah., my old, phone had a 1750mah battery and I can deal written the battery life. I just want to still use my case for my lg connect.
I have heard that 1900 mAh aftermarket is crap and no better than the standard.
Is that so? I guess it depends where you buy the battery from. I'm just worried about my, phone getting too big but maybe I may get used to it But idk :/
It probably does depend on where you buy it. Definitely, don't buy no-name cheap Chinese batteries online unless you can return it back at no loss. I bought an extended no-name 3600 mAh battery, and it lasted no more than the standard one. Luckily, I was able to return it at no cost due to Amazon.com awesome return policy (it was sold by some merchant at Amazon.com participating in Prime); I claimed it was defective. On Chinese wholesale websites, they sell these extended no-name batteries at $3-$5 a piece. No wonder must of these batteries are junk.
Makes sense, mine is directly out of an optimus and works fine, second day out and haven't charged it since 530am and haven't gotten lowbat warning
