Accessories External Charger
If you've got a bit of money to spend I'd personally recommend a Power Monkey. It has multiple connections for use with several devices, it has a storage battery for charging on the move and the storage battery itself can be charged via mains or solar power. A very flexible charging device.
Well, I must say, considering this portable charger is very cheap, it does a fantastic job.
I play alot of games, which kills my battery in about 3 hours. So when my battery went dead, I plugged the portable charger in (portable charger at 100%), I then continued to play my games, the charger lasted around 45 minutes, then the charge on my phone after that, lasted a few hours.
Remember, I was constantly playing games, so the battery will last much longer for normal use.
I recommend it!
