Help Facebook for HTC Sense Help
v1nce
For the most part, Facebook for HTC sense has been working great and syncing with all my phone contacts. However, I came across 1 Facebook friend that wont 'link' with the corresponding phone contact. When I try to manually sync that phone contact with her Facebook, it is no where to be found on the list of friends in Facebook for HTC Sense. The actual Facebook app, however, lists her.
In other words, total fb friends = 396. Android fb app lists 396 friends. Facebook for HTC sense says = 395. I believe this is why I cannot link the contact.
Things I've tried: Removing Facebook for HTC in the Accounts & Sync setting and adding it again. Removing Facebook for HTC app in the actual desktop facebook.com site. Removing the contact as a facebook friend then re adding her.
Thanks
Have you tried removing the google contact and readding...sync google contacts...sync facebook....then try and link
It's not really a problem with syncing. It's more Facebook for HTC sense not recognizing the Facebook friend even exists. In any case, I did what you said with no luck. Thanks though
Its odd that it isn't recognizing that one. All the others work fine? Do this...go to apps.people. menu.view....is facebook checked there? Also try the same but instead of menu click on the round internet icon...its blue...then click facebook. Is she listed there? There was also a trick a while back of going into your facebook profile and changing something in your details...then save...go to phone and try and sync. Then there is the ever so dumb question of..are you sure you are spelling her name right...stupid question...but it happened once
Thanks for the help Mr. Ed. Unfortunately, after doing all the things you've said, I still can't get fb for htc sense to recognize her. Funny thing is I made a couple new fb friends today and they were recognized right away. Anyone know of any security/privacy setting friend side that prevents fb for htc from grabbing the contact?
Well, I know that this happened to me before on the hero, and all I did was wait a few days. I don't know why it happened or how it was fixed. I noticed it was also the one person I contact all the time
ok last try...
open facebook on a pc.
click on account
account settings
mobile (i think. my account settings won't load for some reason)
in here should be a listing of things you allow to communicate with facebook
find and remove htc
next time you sync from the phone it should ask for you to approve access..sometimes it does it on it's own
wish i could direct you straight to it but it isn't working for me right now.
if that doesn't work I don't know what else to try...give it a week..maybe do a hard reset after that
