Root FaceLock For Apps
thebryceee
Android Expert
For those that are unaware, there's an app available called FaceLock For Apps that can enable facial recognition to unlock your phone like ICS.
Visidon AppLock just locks apps, right? Or are you using the paid version with the experimental lockscreen feature? I just assumed being experimental it wouldn't work, but if anyone can verify it works I'd pony up the $2.
I have the paid version, but never tried the lockscreen function. I'll try it and report back if you want.
So I've been playing around with the lockscreen feature (beta) of Visidon App lock.
It seems to work just fine with CM7.
The only issue i noticed is that you'd probably want to disable the long press of the back button to kill apps feature in CM7, if you had previously enabled it.
