...Anyone know if this is something that just started happening? Anyone who did a factory reset affected by this?
And when you consider that if you port a number it does a factory reset on the X that could get ugly. I know I did not port my number for 10 days and when I did it reset and the tech I spoke with said it was a feature.
Whoa, are you sure about this? I'm currently on my 30-day trial with the Droid X and will be porting my number later this week. Are you telling me that when I port my old number over to my Droid X, I have to do a factory reset? I have spent a LOT of time customizing my phone and downloading apps. Are you saying I'll have to start over from scratch when I port my number? :-(
I don't think this is correct. I just ported my number over and it did not do a factory reset.
All I had to do was dial #228 (I think that's the number sequence) after the port and it activated the new number. No reset was done and the number ported over fine. They have an automated system for porting number over (can't recall the 800 number I had to call for the auto system) and the whole process took less than 2 hours.
