bezerk19
Anyone know how to do a factory reset within Clockwork?
When you hold the up/down volume rocker + power button you get the following options:
Android System recovery (2e)
Samsung Recovery Utils
-for BML -
reboot system
apply sdcard:update.zip
wipe data/factory reset
wipe cache partion
If i select 3 - wipe data/factory reset will that only do a "factory reset"
If i select apply sdcard:update.zip, in Clockworkmod i get another option to
Which is the one i should use? and by doing so is this equivalent to "Factory Reset" within Android (selecting the factory reset check box)?
-for BML -
reboot system
wipe cache partion
