Help factory reset
maw4bc
what are some of the draw backs to doing this? I have 17,000 text messages and the phone is absurdly slow. Obviously its impossible to just delete the text as it is way overloaded to delete. Which to me makes no sense considering I can do a factory reset quicker than it takes to delete one thread of text. I've never understood that about this phone.
So what all do i need to back up when doing a factory reset?
So far I have:
Sync with app brain (to then download once reset)
Save widget settings
Anything else?
So far I have:
Anything else?
my backup pro is better to use and you do not have to be rooted. just backup what you need and go ahead and do the factory reset.
it is absolutely absurd that it takes 5 seconds to do a complete factory reset of the phone but takes DAYS literally DAYS to erase large threads of text messages.
MIND BOGGLING
well, yeah you have 17,000 text messages!!!!!!!!! lol
haha I know! but even when I get to like 5k it slows down a lot. The problem is I HATE having to sit there and erase my texts, then they just build up, and next thing I know I can't erase any of them!
Arghhhh just venting. For anyone out there that has used MY Backup Pro, is there a way to get the "Data" portion back without bringing the text messages back? I accidentally backed those up when I did this and the only option to bring everything back is "Data", it isn't broken down more than that.
Why not set your phone to delete texts after "x" amount? I have mine set to delete after 200 text per conversation and it runs as smooth as the day I bought it!
I have my text messages to not go over 100 per person and for some reason, they are all around 120, 103, 115...etc
