alanbingham27
I had to factory reset today and it had wiped everything on my SD card. It has wiped precious photos of my kids. Was the hell has it wiped my SD card?
When you factory reset there is an option to reset SD card, if you had this checked then it will have wiped everything on your SD card too
Bog standard Sensation running stock Android 2.3.4 here, as updated via Orange. The factory reset option does have a checkbox to erase the SD card and it defaults to not checked.It could be because i'm running a custom ROM though. Can anyone with a standard Sensation confirm?
Or a cosmetic change: checking my Desire running a stock Android 2.2 install, the factory reset specifically states that SD card contents will not be erased.Potentially an option added in 2.3.4 then...
