alostpacket
Over Macho Grande?
Hey all, it seems changing my Gmail password has done something weird to my maps.
In the regular "maps" application I can't load any of my saved Google maps. It just says loading... then "Failed to Load My Maps" with no recourse given
The new password works fine in other applications (GMail, etc.). And the maps are able to be downloaded and viewed just fine by the "My Maps editor by Google" app. So I'm really not sure what the problem is, other than it being some obscure bug with the default Maps app.
I have tried the following with no luck so far:
- reset my password to the old one
- uninstalled updates and reset password to old one
- uninstalled updates and tried the new password
Nothing seems to help, just can't get my maps back. I'm getting ready to do a factory reset as this is a pretty important feature to have not work. But, any thoughts or anyone having this problem as well?
The new password works fine in other applications (GMail, etc.). And the maps are able to be downloaded and viewed just fine by the "My Maps editor by Google" app. So I'm really not sure what the problem is, other than it being some obscure bug with the default Maps app.I have tried the following with no luck so far:
