HackADevice
So.. just drop it into my sdcard from my computer works?
I'm wondering if I opened es file explorer and move the bin file from external sd card to sd card does that mean I'm okay?
@ktb; Thank you - I've updated the instructions from your updated post, and FWIW I will keep updating the instructions in step 5 with the current build.
I've tried this numerous times and always get the error " cannot open for read: No such file or directory".
I'm staring at the CMW in my /sdcard.
Thoughts?
This happens on Step 5.
Whoops... "Close the terminal emulator app." should follow step 6. Sorry about that.
I followed the instructions and it works great but 2 simple questions how to u select things using cwm and do I still need to keep the bin file in my sd card??
Someone can correct me if I'm wrong, but I believe you navigate the menu via the volume keys, and either the magnifying glass / search capacitive key or the menu key acts as a select / enter key. Also, once CWM is installed - again someone correct me if I'm wrong - you are able to delete the bin file from your sd card without worry or negative consequences. Wait for verification on either of my statements here before applying them.
Thoughts?
Affirmative this is correct, though I don't think the menu key selects just the magnifying glass/search key
Sobi can delete the bin file?
You might want to add that your phone should be fully charged before attempting this.
Also, ZV5? I ran all system updates, so I should be good, but I don't know where to check for this ZV5 firmware specifically. Looking under Software Version in about phone comes up with LS696ZV9, is that what you're referring to?
LS696ZV9? what is that, sprint software version?
LS696zv9 is the sprint/ting version. It is the only version I know of. So far, 1 person has said that they installed the cwm in a sprint phone and it worked.
Yes.Has someone restored from a nandroid backup?
/sdcardwhat would it be called in root explorer by any chance??
It has only, as far as I know, been tested on VM696ZV5 - that is, the most recent firmware update for the Virgin Mobile Optimus Elite. I couldn't say anything knowledgeable as to CWM's functioning on the Sprint version.
