Root Fascinate Won't Boot
gadgetmom88
I have a fascinate running 2.2 Blackhole ROM, no theme. The battery had been draining in 2 hours. Was thinking of trying a different ROM to see if that would help with battery drain, tried to do a factory reset on the phone, now it won't turn on. Stuck at the Samsung Boot screen. I tried to push the system restore files via ODIN, got the Fail, MD5 hash value is invalid. I tried restoring a clean NAND backup, but the phone won't boot. I can get into CWM red, but that's pretty much it. I'm at a loss as to what to do. Can anyone help please? Would like to set it back to stock and start over from a clean slate.
Are you able to get into stock recovery via holding the volume button in while it boots?
Didn't work. I'm getting the same error. Fail, MD5 hash value is invalid. If I can't push anything to the phone, is it even possible to fix it?
I had the same problem with loading Community rom 1.3 from 1.2 my phone won't boot and out of my 4 or 5 backups none of them would boot either. I had to wipe data and reload 1.2. Then it would boot. I haven't tried anything else since it scared the CRAP out of me so I am waiting for Community rom 2 before I attempt any thing.
Don't be scared... I was the first time mine was stuck on a boot loop. As long as you didn't mess up the bootloader(which is damn tough) and can still get to recovery or download mode, everything will be fine!! :D
