Root FC on TiBU
So I just installed LFY v1.6 with the tangerine theme, after I flashed the theme TiBU keeps force closing and I can't get into it. Any thoughts on what to do? I was thinking uninstall/reinstall but that seems too easy....
I would try a 1 minute battery pull. Then I would try uninstall/reinstall. Then I would try letting the phone hang out for a few hours powered up.
How long have you had the new ROM running?
Are you running a custom kernel?
Cheers
Did you follow the instructions listed for LFY?...more specifically, did you format all of the partitions prior to flashing LFY?
