Help FC & Restarts after upgrading SD card
bigx5murf
Member
I tried putting in my new 32gb sd card to replace my old 8gb unit. But guess my phone got too reliant on the old card, and would only FC, and go into a restart loop with the new 32gb card.
How do I upgrade my sd card?
there's no 'upgrade' option. You should just swap it out and thats it. My guess is that you moved something to the old sdcard and now the phone needs it back on there. Either move everything back off the external sdcard or factory wipe the device and start over with the new card in it.
Those are just my guesses. good luck.
Yep. Sounds like you moved either an app or the data storage location an app needs to your old card.
^ awesome work guys
Also,
When putting your new card in, did you format the new card IN THE PHONE through the phone menu?
