Root Finally rooted... no haptic feedback now?
gaw316
Member
I finally decided to root my phone, installed titanium backup like I read... flashed CW recovery... then i decided to flash the DL09... reinstalled everything lol... rerooted, reflashed the CW recovery, but then I noticed haptic feedback wasn't working on my phone :-/...
anybody have any idea why this is?
Do you have link for dl09 you loaded? It sounds like the problem people were having when going to dj05. The problems were having a dj05 rom but not radio
did you flash a kernel as well? if you were on DI01 before and you didnt flash a kernel thats why
Could I flash any Kernel for this to work?... any recommendations? haha.. I feel pretty helpless.. you roll the dice, sometimes you get bit, right?
If you have setcpu hit the info tab and see if the kernel is made by adrynalyne. Not sure that md5 has the kernel I kinda think it doesnt
I don't have setcpu so I can't check :-/... on the forums he posted it on though someone flashed "stupidfast 1.54" and everything worked they said... so I suppose I just do the same thing I did to flash DLO9... download the kernel, put it in PDA and flash that in download mode?
NO
kernels must be flashed in clockwork, you did install clockwork right?
Now I see you didnt flash dl09 you pushed it though odin. It should have had a kernel, rom, and radio.
Yes I did... just went in and I'm downloading the stupidfast 1.54 kernel now.. after that I checked off back up current ROM, and clear cache... and hit ok.. and now it's prompting me to hit ok to go into recovery mode to continue the install.. which I haven't clicked yet.
If you are going into clockwork through rom manager its going to wipe data..
yeah i hit cancel and unchecked the wipe data box... all is working now. thanks for all the help bro... much appreciated.
I booted up in recovery mode and cleared both caches.. Before that I was getting some fcs.. So I reflashed the kernel. Is that normal?
my bad haha.. Sometimes I neglect things in order to be succinct while typing with my phone. I just deleted one of the tw files .. And I had fbook.sync on for contacts and calendar events and what not :( bad?
If you remove or rename tw launcher apk I forgot exactly what its called you lose the ability to sync FB. For me who doesnt use FB its well worth it since running just one launcher is superior to having multiple
I can't get the haptic feedback either. I did the ota DI09 and was rooted before and after. Then I did the Clockwork recovery and after it rebooted I no longer gad the haptic feedback. I've fixed permissions and rebooted a few times. Any ideas?
