Find Bionic Serial Number
DanDroide
How do I find my Bionic's serial number?
I found numbers starting with "HEX" & "DEC".
Any help is appreciated.
Is it on a sticker under the battery?
Thanks...I just tried that.
I found:
SJXXXXXXXX Model: XT875
MSN: XXXXXXXXXX HWA
IMEI: XXXXXXXXXXXXXXX
Not sure which one would be the serial number.
Wouldn't it also be on the phone electronically?
I'm trying to register with Motorola to be a tester for ICS on my Bionic and they need my serial number.
I found:
MSN: XXXXXXXXXX HWA
They are looking for either the MEID or the IMEI. Both are valid serial numbers. Both are in settings->about phone->status. At least one of them should also be on the sticker under the battery.
See ... MEID or IMEI ... it is in three locations.
... Thom
Thanks everyone & Thom.
One thing of note, when I do the *#06#, that serial number is one digit short as compared to the IMEI under the battery and/or using Settings > About Phone > Status.
I just entered the longer number. Hopefully I'm part of the ICS test.
Cheers!
Under my battery and in phone settings, my Bionic shows 15 digits. When I dial: *#06# it cuts the last number off. In Motorola's instructions it said that it should be a 14 digit number, so I went with that.
Does anyone have any insight into why the numbers are different?
Droid Bionic, Stock-Rooted, .893, foreveroot
Actually, I spoke to Matt (Motorola forum monitor) and he said they wanted the SHORTER (by 1 digit) number when I needed to enter it for the soak tests.
