Help finding hidden settings
Welcome to our AndroidForums, kleangene! :)
You should be able to go to Settings -> About phone -> scroll to the bottom of the list -> tap on the Build number entry seven times (I believe that's the right number)
You'll see toast messages pop-up indicating that you're about to enable Developer settings.
After you see the final prompt, press the back button and you should now see the Developer options in your main Settings menu list.
Cheers!
