Help First 3 things to do with S4
This is my first time with an android phone. I see three options in the developer screen: window animation scale, transition animation scale, and animator duration scale. I turned off all three, but still see an animated transition when I open a folder of apps. Is there anyway to shut that animation down?
Not sure, I don't have them on my international version. Might want to head over to xda and check the section for your specific carrier. Your the first person I've seen mention these animations btw which is a little odd because a lot of people don't like them and shut them down for that reason.
After turning off the animations, you have to do a restart for the changes to work. Restart your phone and you should be good.
Interesting that the suggestions of what to do are predominantly 'turn off Samsung features'.
If I wanted a phone that didn't use S voice or eye tracking / air gestures, I'd have gotten a HTC One. Might as well get that or a lower grade Samsung phone if you're going to switch off the features as soon as you get it :p
The first 3 things I'd suggest:
1. Root the phone
2. Disable animations (although I hear an upcoming update will fix laggy transitions)
3. Install Wallpaper Wizardrii or similar to get non-zoomed, non-pixellated wallpapers working
As for what I got rid of; that's limited to some of the junk apps like TripAdvisor and Flipbooks that come with the phone, as well as some Google apps I didn't want/need.
Really people are rooting this phone first thing? Doesn't that hurt insurance or what not too.
Obviously it's an 'at your own risk' suggestion. However, given it's very difficult to actually brick the device and the methods to root are tested and proven, I'd say the benefits of rooting the device far outweigh any inherent risk it carries.
Some carriers are very root friendly, others aren't.
Sprint doesn't care that I'm rooted. As long as whatever issue I'm having wasn't caused by the process of rooting my device, its still covered.
1. Root the phone
While your point is valid, the degree or amount of lag will not bother some users as much as it will others. So utilizing that option to turn off Samsung features is a nice option to have.
Especially considering you have no option of expanding storage or changing batteries on the HTC One.
Yep, first thing I would do with the One is exactly the same including getting rid of its useless junk aka features. As to rooting the phone it can be returned to stock if any warranty issues come up.
The Samsung rep told me they have software that can tell if a phone has been rooted or not. I have no idea if they actively pursue the issue if someone returns a rooted/restored phone though. I suspect not.
