Root First Stock ROM for the Samsung Transform Ultra
chevanlol360
Android Expert
This is the stock ROM for the samsung transform ultra no data no add ons no nothing its completely stock.
Note this is not Odin for the Ultra the only way you can get back to stock using this method is with CWM.
Disclaimer: I not responsible for any damage or problems caused to your device try this at your own risk, i have already tested it on over 5 different ultra's and they all turned out fine.
New rooters that are eager to try out ROMs and themes might forget or lose the backup of their stock ROM. When something goes wrong with their phone for example they get a bootloop after installing a ROM. Therefore i am releasing this stock rom so that users can always have a restore to it.
stock_rom_screen_shots_2.jpg stock_rom_screen_shots_4.jpgstock_rom_screen_shots_5.jpg stock_rom_screen_shots_1.jpg
Most of the below instructions are words from my firend smith058,
How to install this ROM with CWM
- download... unzip the file then place it into /sdcard/clockworkmod/backup/
- reboot into cwm
- BACKUP YOUR PHONE NOW!!
...after backup
- wipe data/factory reset <------(Required)
- yes delete all
- backup and Restore
- advanced restore
- choose the file name STOCKROMFORULTRA
- Restore system
- Yes -Restore System
- Reboot
If you get a MD5 mismatch error make sure that there is no spaces in the folder name
The first booting of the stock rom might take some time ETA 2 mins
After phone successfully boots and all the applications are up and running reboot your phone one last time, and there you go you are now running stock rom for the ultra.
Download Here ------> StockROMfortheSamsungTransformUltra.zip
yeah i opened the MD5 file and look through it before i posted this and then i did find a couple of the stuff that i deleted written in the MD5 file so i deleted them but im gonna test it when i get the chance,
Update
well we know that the MD5 written code and file names in it wasnt the problem because i deleted it but kept the system. ext4 file name in the MD5 file and it still game me the same error.
anymore suggestions? please keep em coming.
:Dwhen you messed with the zip you ****ed the md5! it wont work at all if you open it and mess with it!
sorry didnt see you got it going? hows about sending me the link?
Awesome work. I am sure this will help lots of people, I am going to download it now just to be safe. It never hurts to have a copy of stock ROM! :)
The "First" lol nice!
- reboot into cwm
...after backup
- yes delete all
- advanced restore
- Restore system
- Reboot
If you get a MD5 mismatch error try re-downloading the zip
im not in this for the fame and glory,... but... copy and past.... realy??? you can do better than that cant you? at least give credit if your going to do that... ???
I had change a couple things around lol the only thing i copied and paste was the install with cwm instructions and a couple other things but sure i'll give you credit in the post :)
all seems well...default apps and rom...only problem im running into is there is no swype...is this the boost stock or the sprint stock....
No Swype!!!! My Data Is Barely Working..... Why Is That????
Werent you having that problem before u went back to stock???? This is stock rom and the stock rom doesnt have any 3g tweaks or anything completely stock, even while flashing to different ROMs it does nothing to your signal/network whatever you dis to your phone rlly messed It up the 3g so its not the stock ROM and i know that swype isnt in it i will add it tomorrow
FYI - By restoring my phone with your stock-rom, it recovered corrupted files which killed my wifi and internet 3g access completely, and it actually took care of fixing my root permission access (/system/bin/sh error No Directory (2))
Thank you so much man, I appreciate your help.
anytime just glad i could help:)
