Root First Stock ROM for the Samsung Transform Ultra
Come on ppl start msging me:), if you have your current rom backed up no need to be worried all should go well :cool:
i am on stock rom boost samsung TU and i would like to use megatron 6.2.5 and last time i was on 6.1 and i really like the rom but when i upgraded i F@#ked my phone up so now i want to slowly install the right way can you help i just got my phone back from being repaired and i dont wanna F@#k nothing up again
Yeah cause you installed 6.2.5 for the wrong phone lol. Follow the instructions from this thread for your specific device. http://androidforums.com/showthread.php?p=4907625 6.2.5 for your device is currently in beta stages. I highly suggest you stick with 6.1.1 until you receive the ota update notification when 6.2.5 is released for your phone. Its always safer that way;)
Hey chev will this still keep the phone rooted, my wife wants to go back to stock from megatron 6.2.5 and this stock is it 6.2.5, just making sure I don't f**k up.
No this is an outdated unroot method. Follow the instructions in this thread to unroot back to stock. The method I linking to you will also remove cwm from your device, no cwm no root, all stock.
http://androidforums.com/showthread.php?t=642509
Hey chev, I'm on megatron 6.2.5 and bout a month or so now, everytime I reboot my phone, the ota update has been popping up and I just wanted to know if I should update it or just keep ignoring it..
Well the reason why that is, is because 6.2.5 was a bit unstable and I didn't exactly leave the ROM in good shape when it comes to 6.2.5. If you choose to install the update it will downgrade you back to 6.1.1, which is my opinion had way less issues than 6.2.5 but if you're not experiencing any issues then stay on 6.2.5. If you wanna disable the notification then go to MT Settings and tap on ota updates and when the app opens hit the menu button and tap on settings then you can unchecked the notification settings.
