Wow, okay thanks guys, it SEEMS to be working perfectly. Better and faster than before. I'll update here if I have any problems or concerns.. but for now my only question is there anything I should know about that I can do with this now that it is rooted that I may not now?
Does the 'Move to SD card' function work properly? I was hoping I could use that to help keep memory free.
Yep got both of those flashed onto it.
Okay will do. One more question.
If I were to buy a larger SD card and copy the files of this one onto it, would I be okay?
Just an idea..
And you also suggest doing another backup shortly? It won't overwrite the original will it?
Have to go for a bit. Thanks for both of you guys help. Very much appreciated. And again i'll be sure to return with other concerns if I have them.
If I tried to do this on a phone without the 2.1 update, would it still work the same way? My girlfriend has one that was never updated.
By the way, our phones our Cellular South if that matters. It didn't for mine obviously.
Also, is there a way to change the keyboard layout, or should I just find an app?
Sorry hate to ask this twice but I need to know if this same process will work for an older firmware Hero. I think it has 1.5?
This thread rocked! Technically speaking I just evolved from tree dwelling to knuckle-dragging! Rooted with no prob using the z4, but ha(ing probs with the gingerbread install: no internet access. Seems important I have that. I have a 16gb card in my phone (early attempt to create space, speed, etc.) Do I need to reinstall the factory 2gb card for the drivets, etc. when i flash gingerbread again? Mucho Thanx for ALL the help you guys!
Dangitt! Followed to a T, but same result. I have the alpha version, should I.try beta, or a different version of android? But why would this one not work on mine? Hmmmmm...
