mastermind1024
Android Expert
Hi everyone...I m here with highly anticipated adb bug fix which was transmitting amongst A70 roms.
DISCLAIMER:
I am not responsible for bricked devices, dead SD cards, thermonuclear war, or you getting fired because the alarm app failed. Please do some research if you have any concerns before flashing! YOU are choosing to make these modifications, and if you point the finger at me for messing up your device, I will laugh at you.
You need to flash this new boot.img file.I will guide u through process.
WARNING:
If u r using DtA2SD then flashing this boot.img will disable it so please don't flash it.I can provide newer boot.img with DtA2SD support on request.
Link2sd has no issue.I am using link2sd on kanged hybrid3 with this boot.img,working perfect.
Tested by me & varun.chitre15 (we both on hybrid 3)
If this solve your adb problem then reply "Solved" with your "rom name".n don't forget to hit Thanks.
And please don't quote whole op.
Let's start the process.
Downloads:
Just grab this: Boot-A70
[Newer] boot.img (adb bug fixed,init.d support & no dta2sd) now with flash...
If u have all necessary tools and u want only boot.img then here it is: boot.img (I think u know what to do next so I m not explaining...)
Steps:
1.) Extract the zip file to a folder of your choice.
2.) Turn off your mobile.
3.) WHILE HOLDING THE CAMERA BUTTON, Connect the usb cable to the phone (and PC too
4.) Just go to extracted folder using Explorer and double click install-boot-windows.bat file.
For those who downloaded boot.img only, place boot.img in folder containing fastboot.
Follow upto step 3.
4.) Open cmd prompt and cd to the directory of your fastboot folder.
Example: If have extracted to D:\Boot-A70, then use:
5.) type:
6.) Done.
The package contains tools and scripts for linux and mac too.
If u unable to use fastboot on linux then tell me,I will guide u.
HIT THE THANKS BUTTON IF I HELPED...
DISCLAIMER:
WARNING:
Downloads:
Steps:
).4.) Just go to extracted folder using Explorer and double click install-boot-windows.bat file.
Follow upto step 3.
Code:
D:
cd D:\Boot-A70
Code:
fastboot flash boot boot.img
It may be a problem with drivers, or with the cwm recovery??
