Help Fix for the yellow tint?
El Presidente
Beware The Milky Pirate!
If found this app whilst trawling through some threads on XDA regarding the screen issues: https://play.google.com/store/apps/details?id=com.kovit.p.filteryourscreen
It works to a degree, if I play about with the settings, whites certainly look better than they do stock, but I'm concerned about long term damage to my screen? Would it be an issue?
Whilst I do have a yellowish tint that's totally noticeable on white backgrounds, I don't find it that big an issue (certainly not a deal breaker), so if there's any danger of long term screen damage, I'll stop using the app.
Nope. :(
The only config options I have are X-Reality, Brightness & Optimized Backlight.
I've only played with the original Z briefly, but you guys have much more options don't you?
Yup, but the Z doesn't have the new X-Reality/Triluminous display. Perhaps WB adjustment is done automatically, kind of like how the Bravia Engine (supposedly) optimises contrast and colour?
Maybe, it's not doing a particularly good job though.
As above, it's not a deal breaker, but compare the whites to my old Nexus 4 (or even my One X) and the difference is like night and day.
My serial number is BH904*** so according to this thread, it's (apparently) the type of screen used: [Q] Display verified by serial / build number - xda-developers
There's another firmware update in the pipeline, maybe that will offer some additional WB options.
Reckon there's any long term "danger" to using the filter app in the OP?
Was this a software or a hardware issue? I just bought myself a Z1 and will be delivered on Monday, should I expect any issues with the yellow tint?
I'm guessing hardware, I've had 3 handsets all with differing degrees of yellow tint.
My 3rd is pretty much perfect though. :)
Well, I hope they have sorted the problem by now. As mine comes with the 4.3 update from the box, it makes me think it is a latest built and hopefully will not have the issues..
