Fix homescreen lag (If there is any)
Mohammad_Adib
I noticed after i got my infuse a while back that for some reason scrolling around with a graphics savvy 3d background on the homescreen was very laggy. So if anyone else is experiencing this lag, I suggest you use Launcher Pro. It is smooth no matter what processes or wallpaper you have running, and it brings a lot of functionallity. So basically you set launcher pro as your default home, and never worry about twLauncher(default) ever again :)
Here is Launcher Pro in action: (BTW start from 1:08)
any launcher will be affected by lack of available memory (especially launcherpro)
it definitely will work better than touchwiz imo...but to say one will never have an issue is quite an overstatement... in it's case, rather than lag, it will completely restart from time to time.
the real key is memory/process management...
watch your apps, make sure you have your syn settings set up properly and enjoy!!!!!
