DsyMnapTic
Android Expert
you're gonna need adb and a recovery that you can access adb thru
and then issue some commands
Okay, is it possible that I can get the readout of the commands from you now, so that I can use them in a little while?
I have a tmobil sgh-959v with twrp stuck on it. Someone told me it was a brick how can I fix it?
Everytime I try to reboot it says no OS installed ???
Blah..... Well RB, anyway you could just hook it up with the steps and commands on here? I can't get access to a computer again anytime soon to get on IRC and all. I'm just wanting to know what you have in mind. I'm thinking maybe If I would've done phenoms thing and added just a couple extra steps, maybe it would've worked. I was looking at a forum on xda, that had the same type of mkfs.ext4 push going on. However at the end, they formated and mounted /data through a shell. I didn't, I rebooted recovery and then tried to mount and format data, like phenom told me to. I super trust that phenom knows what he's doing, but maybe it would've helped to do those extra steps.... Who knows![]()
Can u access recovery?? Is it stock recovery??
@Brian85 all u have to do is fastboot twrp then flash ur desired recovery/rom... U cant sideload in 3e recovery due to signatures being checked
