Find the tar file an use Odin!!
There is a FL26 repackaged kernel with custom recoveey you can flash after you accept the OTA update and flash superuser again. Very simple. Its over at SXTP developers.[/QUOT
Could I get a link please? I cant find it.
[KERNEL][SOURCE][ICS] Virgin FL26 + Agat's tREC_v0.2.2
Im using SuperSU and Kuban kernel didnt loose root
this was also my case, im using kuban kernel and i did not lose root, the update went away for two days, and now today it is prompting me to update again, how do i get rid of this update for good, i have my phone exactly how i want it for now, I DO NOT want agat's it always has issues with the apps to internal SD every instance ive used Agat's, i love my overclocked Kuban kernal. is there something i can delete from my system files or an app i can freeze so it will shut up about this update?????
