Flash 10.1 on eris question
Joe Eris
Ok so I installed adobe flash 10.1 on my eris yesterday, but I'm not seeing any difference. Does the 10.1 overwrite the flashlite? How can I see which flash is running?
Yea, please share, intrested thought you can only get flash 10 on froyo
Sent from my Eris using Tapatalk
I got it from XDA developers its an apk for 2.1 supposedly works great on eris
From what I've heard it's a farce. Adobe has already stated multiple times that the 10.1 update cannot operate independently from 2.2, it relies on part of the software to function.
Strange, cause my buddy did the same thing as I did & he claims his you tube and jetflicks play much much better?
Tried the skyfire browser? It works good for me...well only with certain videos...
I know that Dolphin Browser HD released an update today that added support for Flash 10.1 for Froyo, but I assume it means Flash 10.1 all around. Haven't tried it yet, though.
I don't believe you will see any noticable difference. THe Flash 10.1 that is available with 2.2 relies on an ARM8 processor, while our Eris' only have ARM6. THe hardware will never keep up with the demands of the program.
So has this worked on anyones browser? anybody able to see videos that run flash 10?
It does work. Very well? no, but it does work. I used games from Addictinggames.com to test it and they played perfectly, but you could not control the game. When trying videos, very few worked. When I unistalled, I went back to the games website to test if they would still play with flashlite but they did not. Its a very large "application" that does not much more than flash lite. BTW it does not improve the quality of flash videos so I would not recommend it.
