flash player
Yup. Go to the adobe flash website, go to the archive and install the newest android 4.0 version (doesnt matter if youre on a higher version of android) first go into the tablets settings, Security, and check the box for "unknown sources" :thumbup:
I have Similar Question! Looking for Answers on how to custom Code For 'Android' Samsung Galaxy S3 to be able to use 'Flash Player'!
Welcome to our AndroidForums, mrmkarndt :).
If you are talking about app development for Flash, it's typically done via Adobe Air. Here are a few links to help you start:
Flash Player Developer Center | Adobe Developer Connection
Adobe AIR and Adobe Flash Player Technologies | Flash Platform runtimes - Adobe Labs
Developing and using Adobe AIR native extensions for Android devices | Adobe Developer Connection
Learn AIR | Adobe AIR Developer Center
..., etc. (lots of other sites/links, too numerous to list).
Cheers and best of luck!
