Help Flash won't work
p_025
Yeah, I can't get flash to work in the browser or anywhere. I have the most recent Flash version from the Market but I don't know what the hell else to do besides install it. It won't work in any browser, I just get the picture of that stupid lego.
Still have this issue? Which message do you get exactly? And you get it over WiFi and 3/4G both?
It doesn't work for me either. I noticed it using Firefox browser, just the generic looking icon thingy.
Mine doesn't matter if I'm using wifi/3g/4g.
Firefox on Android doesn't support flash. You have to use either the stock browser or another one that does (I use Dolphin HD, it works great with Flash)
i suggest Opera mobile, it supports flash, and has operas 'turbo' feature built in which compresses the webpage on their server, sends it to your browser (phone in this case) and then uncompresses it and displays it, speeds up the web when on 3g and saves you some data if you are on a low data allotment plan.
