Help Flash
Do I need adobe flash on my android? It sure takes a lot of memory on my phone if I am not going to need it! If I do, can I move memory to SD card?
Thank You,
Michael
Thank You,
Michael
well you do not necessarily need flash. the only time you will need it is if you surf the web a lot on your phone and you go to sites that needs flash to run. so that will be up to you.
as far as moving memory to your card that is not possible unless you are rooted.
and apps2sd will not help very much as only part of the app gets moved to the card. the rest stays on your phone. you can root your phone then move cache, data, and even your apps to the card. it is recommended that you have a class 4 or higher to partition your card like that.
