Joeseph Mother
Two different zip files here, the first will enable hardware acceleration, to make your scrolling & other graphic effects smoother, the second will enable hardware acceleration & stagefright, enabling stagefright is a catch 22, it will enable winamp & npr radio, but may cause problems with playing certain formats. Enabling stagefright may also boost your quadrant scores quite a bit, but it's a false boost, it doesn't make anything faster, it causes quadrant to skip the h264 test.
To use, just download the one you want, put it on the root of your sd card, and apply zip from custom recovery.
Download hardware acceleration here.
Download hardware/stagefright here.
Oh, by the way, the sprint recovery works on the v, with only 1 button being mapped incorrectly.
