Prophetless772
Let's see if I can explain this in depth and detail to get the most help.
I have a ZTE Boost Force and am fairly new to rooting. Everything was fine until I decided to flash my first rom, Droidsmith (link: http://androidforums.com/boost-mobi.../697658-rom-droidsmith-1-7-3-update-full.html). I went to backup before and it had some error (something about unable to format /system, or something?), but stupid me decided to wipe data/factory reset, wipe cache, wipe davlik cache anyway. Uploading the rom is fine. It says "Droidsmith is ready to rock" and all, but when I reboot, I just get a black screen and a solid red notification light. I know the forums say that the first load will take awhile, but I'm sure they don't mean 15 minutes, which is the amount of time I waited. I can still enter cwm recovery, but with no backup and no booting of the rom, is there any hope for me?
(Remember, I'm fairly new to rooting, so I dont understand a lot of terms. Basically, dumb it down for me. Thanks!)
