Root Flashed to boost - Suddenly will not send MMS - HELP !
Like the thread says - I suddenly lost the ability on my evo to send MMS. I can receive just fine.
1. I check my settings ##3282# - MMS Server URL is BLANK. I edit this to say http : // mm. myboostmobile ( you guys know what this is lol ) Hit OK and settings do not stay. They instantly go back to being blank.... :(
2. tried apn back up and restore Application- my APN file i created however is pretty much blank. Anybody have the proper boost .APN file ?
3. Updated PRL and Profile - Still will not work for the evo's stock messages app for MMS
4 . A FIX - ( but i want stock to work again )
GO SMS PRO - when i changed the MMS settings manually
any help would be much much appreciated guys
Please close thread... I fixed this issue by changing APN... if anybody needs to know here is the correct settings for boost mms only change to be made is the YOUR FIRST AND LAST NAME ( change it to what your boost acct is setup under )
<?xml version='1.0' encoding='UTF-8' standalone='yes' ?>
<apns count="1">
<apn name="Production" numeric="00000" mcc="310" mnc="00" apn="1" user="YOURFIRSTANDLASTNAME@myboostmobile.sprintpcs.com" server="null" password="null" proxy="null" port="" mmsproxy="" mmsport="" mmsprotocol="2.0" mmsc="http://mm.myboostmobile.com" type="mms" />
</apns>
<apns count="1">
</apns>
no need to close the thread. it might provide a place for others to find help. thanx for posting your solution.
if you want to really close it, just hit the report button and a mod will close it down for you.
