I have successfully rooted my phone and flashed the Backside ROM per Whyzor's howto guide. I'm comfortable with backing up and restoring various builds of Backside, finally settling on the 01312012 build.
Now its playtime....
I want to try ICS/CM9 and am working through the various posts here. However, I am a bit confused...when it comes time to actually flashing CM9 do I just boot into my existing recovery, clear the various caches and then flash CM9? Or start from scratch?
Currently, I have CWM-based Recovery v4.0.1.5 installed.
There is a method to my madness: I want a CM9 backup on my SD card so I can activate an OV after it is rooted (thanks to whoever posted this idea)....if this works I'll probably get my kid an OV, root it, send it to her with ICS then walk her thru restoring it back to Backside once she activates and ports her number to the OV....does this sound like a viable plan?
