johnny424
Android Expert
For those of you who have done the S-off procedure, will remember that after the wire trick is successfully completed Controlbear prompts you to install the Juopunutbear Hboot..yes to install no to keep the stock Hboot..i opted to keep the stock Hboot but later changed my mind..wanted to flash the jp Hboot but ran into trouble because the download for shooter ics that UnlimitedIO provides was missing an important factor..
I ended up getting some sort of error and had to go to UnlimitedIO's IRC channel for some help, and provide them with a patebin of my output..
Thanks to Burgd from UnlimitedIO for making the updated zip for us..
Instruction's to flash the Juopunutbear Hboot can be found on the UnlimitedIO site..
Do not download the shooter ICS jb_hboot.zip file that they provide, atleast untill they update there links
Use this fixed jb_hboot.zip---------> jb_hboot.zip
the correct download will have SPCS_002 in the android-info text file inside the jb_hboot.zip
Just thought i would share this to save someone else the trouble
Link to UnlimitedIO's website with all instructions-----> http://unlimited.io/
:smokingsomb:
