I was just wondering, if I partitioned my SD already do I have to go back and do it again after I flash a new ROM????
Granite 1,
Sorry Im a complete newb to this rooting thing. When you say wipe the SD partition do you mean undo the partition then redo it before you flash a new ROM? These are the steps I take when flashing a new ROM, please point me in the right direction if wrong.
-Nano Backup
-Wipe (cache, dalvik cache, data)
-superwipe
-Flash new ROM
Am I missing a step? If so can you provide details on what else I should do? Also if I have flashed a new ROM with the steps I have listed do I need to go back wipe and re flash? Sorry for all the Q&A but like I said im a "NEWB"
ps: I have flashed about 8 ROMs going back and fourth using these steps, hopefully I havent screwed anything up.
is the wipe sd ext in the same place as the wipe for the others. If I did not do this currently should I re flash??? If I do a nano now then re flash wouldnt I be stuck with the same stuff on my sd????
Thanks a lot. I actually finally have my phone running great right now with MikG 2.5 and Goldenmonkey. I will be sure to do this in the future! I do have Titanium though. Next on my list is to do the supercharger script if I can ever figure it out. Im such a NEWB
Do you ever have to redo setting it up, such as if I reboot my phone or flash a new kernel?
....and when you make a nandroid include sd ext. as well in the backup...
if you go to the rooting guide under partitioning you'll see....
http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html
Sorry I should have specified. I was wondering if you hav to re-setup the V6 super charger script?
