Help Flickering Screen
Missjojo
I seem to be having an issue with my phone. Everything seems to work perfectly on my phone except for the screen flickering. I can make phone calls, use apps, listen to music etc, just can't seem to get the screen to stop flickering. Help!
It could be a rouge app causing it, it could be a setting changed in the system settings in dev options, or it could be a cable has become unseated. Either way, all easy to fix.
I an looking to see about getting it fixed. Haven't really had an luck with finding any troubleshooting guides for this phone. Any suggestions?
I would check the internal connections, factoey reset your phone, if not i would assume its just the lcd going bad. But my f6 has flickered a couple times but only for a sec or two, plus my screen sensitivity seems to be going out.
